Configure an IPv6 IS-IS accept policy for a specific I-SID to represent local or remote Layer 3 VSNs, which allows the system to redistribute the remote VSNs to the VSN where you applied the filter.
If the route policy changes, you must re-apply the IPv6 IS-IS accept policy, unless it was the last sequence in the configuration.
Enable IS-IS globally.
Ensure the manual area exists.
You must configure a route-map.
Change the VRF instance as required to configure an IPv6 IS-IS accept policy for a particular I-SID on a specific VRF instance. Not all parameters are configurable on non-default VRFs.
 - Select IS-IS.
 - Select the Accept Isid tab.
 - Select Insert.
 - In the Isid field, specify the I-SID value.
 - Select Enable to apply the filter.
 - Optional: In the PolicyName field, specify the route-map name.
 - Select Insert.
Accept Isid Field Descriptions
Use the data in the following table to configure the Accept Isid tab.
 Name  |
 Description  |
 Isid  |
 Specifies a particular I-SID number that represents local or remote Layer 3 VSNs to which the IPv6 IS-IS accept policy applies. An I-SID value of 0 represents the global routing table (GRT).  |
 Enable  |
 Enables or disables the I-SID entry. The default is disabled.  |
 PolicyName  |
 Specifies the route policy name.  |
