Configure RIPng Globally
Configure RIPng global parameters on the switch so you can control RIPng behavior on the system.
All router interfaces that use RIPng use the RIPng global parameters. Both brouter ports and VLAN virtual routing interfaces use the same RIPng global parameters.
You can configure RIPng on interfaces while RIPng is globally disabled. This way, you can configure all interfaces before you enable RIPng for the switch
- In the navigation pane, expand Configuration > IPv6.
 - Select IPv6 RIPng.
 - Select the Globals tab.
 - Select enable.
 - Configure other global RIPng parameters as required.
 - Select Apply.
Use the data in the following table to use the Globals tab.
 Name  |
 Description  |
 AdminState  |
 Enables or disables RIPng globally. The default is disabled.  |
 UpdateTime  |
 Specifies the time interval between RIPng updates for all interfaces. The default is 30 seconds, and the range is 1–360.  |
 GlobalHoldDownTime  |
 Configures the length of time that RIPng continues to advertise a network after the network is unreachable. The range is 0–360 seconds. The default is 120 seconds.  |
 GlobalTimeOutInterval  |
 Configures the RIPng timeout interval. The range is 15–259200 seconds. The default is 180 seconds.  |
 DefaultInfoMetric  |
 RIPng default-information metric.  |
 DefaultInfoState  |
 Default-information enable or disable at the global level  |
 DefaultImportMetric  |
 Specifies the RIPng default import metric.  |
