Inter-VSN allows you to route between IP networks on Layer 2 VLANs with different I-SIDs. Inter-VSN routing is typically used only when you have to extend a VLAN as a Layer 2 Virtual Services Network (VSN) for applications such as vMotion. Use IP Shortcuts to route traffic. You must configure both the Backbone Edge Bridges (BEBs) and the Backbone Core Bridge (BCB).
![Note](images/note.png)
To enable inter-VSN routing, you must configure the IP interface where the routing instance exists.
You must configure the required SPBM and IS-IS infrastructure.
You must configure the BEBs that contain the VSNs you want to route traffic between. For more information, see Configure BEBs for Inter-VSN Routing.
Follow these steps to configure the BCB for inter-VSN routing.
On the BCB, create a VRF:
- Select VRF.
- Select Insert.
- For Id, specify the VRF ID.
- Name the VRF instance.
- Configure the other parameters as required.
- Select Insert.
Create a VLAN to associate with
each VSN:
Associate the VLAN with an
I-SID:
- From the same Advanced tab. navigation path, select the
- For Isid, specify the I-SID to associate with the specified VLAN.
- Select Apply.
Configure a circuitless IP
interface (CLIP):
- Select IP.
- Select the Circuitless IP tab.
- Select Insert.
- For Interface, type a CLIP interface number.
- Provide the IP address.
- Provide the network mask.
- Select Insert.
