View the I-SID interface
 - Select ISID.
 - Select the Interface tab.
 - Optional: Select Filter to filter rows on specific filter criteria.
Interface Field Descriptions
Use the data in the following table to use the Interface tab.
                                 Name  |
                                 Description  |
                                 IfIndex  |
                                 Specifies the interface index  |
                                 Isid  |
                                 Specifies the service interface identifier (I-SID).  |
                                 Isid Name  |
                                 Specifies the service interface identifier name.  |
                                 Vlan  |
                                 Specifies the platform VLAN.  |
                                 Cvid  |
                                 Specifies the customer VID.  |
                                 Type  |
                                 Specifies the type of service associated with the I-SID interface.  |
                                 OriginBitMap  |
                                 Specifies the origin of the service associated with the I-SID interface.  |
                                 Bpdu  |
                                 Specifies the BPDU forward option for the untagged traffic port.  |
                                 MacBased  |
                                 Specifies the Switched UNI MAC address.  |
