Use IP forwarding (routing) on a global level so that the device supports routing. You can use the IP address of an interface for IP-based network management.
You cannot configure this option on a DvR Leaf node.
Activate IP forwarding and view the forwarding configuration:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#router vrf green
Switch:1(router-vrf)#ip routing
Switch:1(router-vrf)#show ip routing
                               IP - GlobalRouter
 IP Forwarding is enabled
 IP ECMP feature is disabled
 Maximum ECMP paths number is 1
 ECMP 1 pathlist :
 ECMP 2 pathlist :
 ECMP 3 pathlist :
 ECMP 4 pathlist :
 ECMP 5 pathlist :
 ECMP 6 pathlist :
 ECMP 7 pathlist :
 ECMP 8 pathlist :
 Gratuitous-Arp  :  enable
 IP Alternative Route feature is enabled
 IP More Specific Non Local Route feature is disabled
 IP ICMP Unreachable Message is disabled
 IP Supernetting is disabled
 IP Icmp-echo-broadcast-request is enabled
 IP Default TTL is 255 seconds
 IP ARP life time is 360 minutes
 IP Source Route Option is disabled
Use the data in the following table to use the show ip routing command.
                             Variable  |
                             Value  |
                             vrf WORD<1-16>  |
                             Specifies a VRF instance by VRF name.  |
                             vrfids WORD<0-512>  |
                             Specifies a VRF instance by VRF number.  |
