Perform the following procedure to configure a specific I-SID and customer VLAN ID to use as the management I-SID when a port is in the Auto-sense FA PROXY state.
The switch creates this I-SID dynamically and uses it instead of the onboarding I-SID.
The following table defines parameters for the auto-sense fa proxy management command.
                                 Variable  |
                                 Value  |
                                 c-vid <1-4094>  |
                                 Specifies the customer VLAN ID.  |
                                 i-sid <1-15999999>  |
                                 Specifies the service instance identifier (I-SID).  |
