Use the following procedure to view statistical graph of the IS-IS interface receiving control packets.
 - Select IS-IS.
 - Select the Interfaces tab.
 - Select an interface.
 - Select the Graph button.
 - Select the Interface Receiving Control Packets tab.
Interface Receiving Control Packets Field Descriptions
Use the data in the following table to use the Interface Receiving Control Packets tab.
 Name  |
 Description  |
 Hello  |
 Indicates the number of IS-IS Hello PDUs seen in this direction at this level. Point-to-Point IIH PDUs are counted at the lowest enabled level: at L1 on Layer 1 or L1L2 circuits, and at Layer 2 otherwise.  |
 LSP  |
 Indicates the number of IS-IS link-state packet (LSP) frames seen in this direction at this level.  |
 CSNP  |
 Indicates the number of IS-IS Complete Sequence Number Packet (CSNP) frames seen in this direction at this level.  |
 PSNP  |
 Indicates the number of IS-IS Partial Sequence Number Packets (PSNPs) seen in this direction at this level.  |
 AbsoluteValue  |
 Displays the counter value.  |
 Cumulative  |
 Displays the total value since you opened the Stats tab.  |
 Average/Sec  |
 Displays the average value for each second.  |
 Minimum/Sec  |
 Displays the minimum value for each second.  |
 Maximum/Sec  |
 Displays the maximum value for each second.  |
 Last Val/Sec  |
 Displays the last value for each second.  |
