Disable ECMP before you configure route preferences
Important
Changing route preferences can affect system performance and network accessibility while you perform the procedure. You must therefore change a prefix list or a routing protocol before you activate the protocols.
Configure IP route preferences to give preference to routes learned for a specific protocol. You must disable ECMP before you configure route preferences.
To configure route preferences for a VRF, access VRF Router Configuration mode, rather than Global Configuration mode.
Configure the route preference to SPBM Level 1 and confirm the configuration is correct.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ip route preference protocol spbm-level1 7 Switch:1(config)#show ip route preference ============================================================================== IP Route Preference - GlobalRouter ============================================================================== PROTOCOL DEFAULT CONFIG ------------------------------------------------------------------------------ LOCAL 0 0 STATIC 5 5 SPBM_L1 7 7 OSPF_INTRA 20 20 OSPF_INTER 25 25 EBGP 45 45 RIP 100 100 OSPF_E1 120 120 OSPF_E2 125 125 IBGP 175 175
View the route preference configuration for a specific VRF, for example 444.
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router vrf test Switch:1(router-vrf)#show ip route preference vrf 444 ============================================================================== IP Route Preference - VRF 444 ============================================================================== PROTOCOL DEFAULT CONFIG ------------------------------------------------------------------------------ LOCAL 0 0 STATIC 5 5 SPBM_L1 7 7 OSPF_INTRA 20 20 OSPF_INTER 25 25 EBGP 45 45 RIP 100 100 OSPF_E1 120 120 OSPF_E2 125 125 IBGP 175 175
Variable definitions
Use the data in the following table to use the ip route preference protocol command.
Variable |
Value |
ebgp |
Protocol type eBGP |
ibgp |
Protocol type iBGP |
ospf-extern1 |
Protocol type ospf-extern1 |
ospf-extern2 |
Protocol type ospf-extern2 |
ospf-intra |
Protocol type ospf-intra |
ospf-inter |
Protocol type ospf-inter |
rip |
Protocol type rip |
spbm-level1 |
Protocol type spbm-level1 |
static |
Protocol type static |
