Configure manual-area in both home and remote area.
Configure the Shortest Path Bridging MAC (SPBM) instance and backbone VLANs (B-VLAN) manually.
Configure the nickname in both home and remote area manually.
Perform this procedure to enable remote IS-IS router configuration on the switch, globally.
Enabling IS-IS router remote configuration globally:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#router isis remote enable
What to do next
To verify the configuration, see Display IS-IS Remote Area Configuration.
The following table defines parameters for the router isis remote command.
| Variable | Value |
| enable |
                                 Enables router IS-IS remote configuration globally on the switch.  |
