Use this procedure to configure a DNS address to advertise to clients within a DHCP
        Server subnet.
 - Select DHCP Server.
 - Select the Subnet DNS tab.
 - Select Insert.
 - In Subnet IP, type the subnet network address.
 - In Subnet Mask, type the subnet mask.
 - In IP, type the IPv4 address of the DNS server.
 - Select Insert.
Subnet DNS Field Descriptions
Use the data in the following table to use the Subnet DNS tab.
| Name | Description |
                                 Subnet IP  |
                                 Specifies the network address of the DHCP subnet.  |
                                 Subnet Mask  |
                                 Specifies the subnet mask for the DHCP subnet.  |
                                 IP  |
                                 Specifies the IPv4 address for the DNS server that you want to assign to this subnet. You can assign up to eight DNS servers to a DHCP subnet.  |
