Display sFlow Statistics
Use the following procedure to display (true) sFlow statistics. Statistics for sFlow are cleared (false), by default.
Tip
You can configure the Stats tab to select only the columns you are interested in seeing. The system displays all the options, by default. To hide a column, select the down arrow on one of the menu headings, navigate to Columns, and select the check box for the column you want to hide.
 - Select sFlow.
 - Select the Stats tab.
 - In ClearStats, double-click the field, and select true or false.
 - Select Apply.
Stats Field Descriptions
Use the data in the following table to use the Statistics tab.
 Name  |
 Description  |
 Index  |
 Shows sFlow collector ID 1 and 2  |
 DatagramCount  |
 Shows the number of datagrams that have been sent to the collector.  |
 ClearStats  |
 Shows whether the sFlow statistics are displayed (true) or cleared (false). The default is false.  |
