Use Software Record Dumps
Capture a dump of the software records from ingress traffic to help troubleshoot performance problems. Generally, a verbosity level of 1 suffices.
Switch:1> enable
Switch:1# dump ar 1 vlan 1
The following table defines parameters for the dump ar command.
 Variable  |
 Value  |
 <1>  |
 Specifies the slot number.  |
 WORD<1-1536>  |
 Specifies a record type in the AR table. Options include vlan, ip_subnet, mac_vlan, mac, arp, ip, ipmc, protocol, all.  |
 <0-3>  |
 Specifies the verbosity from 0–3. Higher numbers specify more verbosity.  |
