View information about BGPv6 neighbors.
The following examples shows the summary output for bgp ipv6 neighbors command, and the advertised-routes and routes variable options.
Switch:1>show bgp ipv6 neighbors vrf vrf1
                       BGPv6 Neighbor Info - VRF vrf1
BGPv6 neighbor is 2015:cdba:0:0:0:0:3257:9652 remote AS 200, External Peer,
BGP state [Established] UP Time 0 day(s), 00:50:30
remote router ID 0.0.0.6
	                            vrf instance - 0
	                             admin-state - BGP ON
	                  connect-retry-interval - 120
	                           ebgp-multihop - disable
	                               hold-time - 180
	                          keepalive-time - 60
	                    hold-time-configured - 180
	               keepalive-time-configured - 60
	                         ipv6-max-prefix - 8000
	                            nexthop-self - disable
	                   originate-defv6-route - disable
	                          neighbor-debug - all
	                       remove-private-as - disable
                    route-advertisement-interval - 5
	                  route-reflector-client - disable
	                          send-community - disable
			   soft-reconfiguration-in - enable
	                   updt-source-interface - 0:0:0:0:0:0:0:0
	                                  weight - 100
                            IPv6Route Policy In -
                           IPv6Route Policy Out -
	                     address-family ipv6 - enable
	                           route-refresh - enable
Total bgpv6 neighbors: 1
			Switch:1>show bgp ipv6 neighbors 2015:cdba:0:0:0:0:3257:9655 advertised-routes vrf vrf1
The total number of routes advertised to the neighbor is 2
                                  BGPv6 Neighbor Advertised Routes - VRF vrf1
NETWORK/MASK                  NEXTHOP ADDRESS                               LOC PREF ORG   STATUS
2001:cdba:0:0:0:0:0:0/64      2001:cdba:0:0:0:0:3257:9651                   100      INC   Best
2007:cdba:0:0:0:0:0:0/64      2001:cdba:0:0:0:0:3257:9651                   100      INC   Used
			Switch:1>show bgp ipv6 neighbors 2015:cdba:0:0:0:0:3257:9655 routes vrf vrf1
The total number of accepted routes from the neighbor is 2
                                  BGPv6 Neighbor Routes - VRF vrf1
NETWORK/MASK          PEER-REM-ADDR               NEXTHOP-ADDRESS             ORG LOC-PREF STATUS
1100:0:0:0:0:0:0:0/64    2015:cdba:0:0:0:0:3257:9655 2015:cdba:0:0:0:0:3257:9655 INC 100 Used AS_PATH:(150)
2015:cdba:0:0:0:0:0:0/64 2015:cdba:0:0:0:0:3257:9655 2015:cdba:0:0:0:0:3257:9655 INC 100 Best AS_PATH:(150)
The following table defines parameters for the show bgp ipv6 neighbors command.
 Variable  |
 Value  |
 WORD<1–256>  |
 Specifies the IPv6 address.  |
 advertised-routes  |
 Specifies an IPv6 neighbors advertised routes.  |
 routes  |
 Specifies an IPv6 neighbors routes.  |
 WORD<1–256>  |
 Specifies an IPv6 address/length.  |
 longer-prefixes  |
 Shows long prefixes. The longer-prefixes indicate the mask length from any specified prefix to 128. For example, show from prefix :X::X:X/len to X:X::X:X/ 128.  |
 community <enable|disable>  |
 Enables or disables the display of community attributes.  |
                             vrf  |
                             Specifies a VRF instance by name (the string length ranges from 1–16 characters).  |
                             vrfids  |
                             Specifies a range of VRFs by ID number (the ID ranges from 0–255).  |
