Use the following procedure to display the SPB-PIM Gateway VLAN information.
 - Select VLANs.
 - Select the Basic tab.
 - Select a row for the VLAN, and then select IP.
 - Select the SPB-PIM-GW tab.
SPB-PIM-GW Field Descriptions
Use the data in the following table to use the SPB-PIM-GW tab.
 Name  |
 Description  |
 OperState  |
 Displays the current operational state of this SPB-PIM Gateway interface.  |
 Address  |
 Displays the primary IP address of this router on this SPB-PIM Gateway interface.  |
 AddressMask  |
 Displays the primary IP address mask of this router on this SPB-PIM Gateway interface.  |
 HelloInterval  |
 Configures the PIM HELLO transmission interval. This SPB-PIM Gateway VLAN level interval setting overrides the inherited global SPB-PIM Gateway HELLO interval setting. Setting the HELLO Interval to 0 causes the neighbors to never expire its neighborship with this local SPB-PIM Gateway interface.  |
 JoinPruneInterval  |
 Configures the PIM JOIN PRUNE transmission interval. This SPB-PIM Gateway VLAN level interval setting overrides the inherited global level JOIN PRUNE transmission interval setting.  |
