View IPv6 RP Set Parameters
View the IPv6 RP set to see a list of rendezvous point addresses and to view the parameters for troubleshooting purposes.
 - Select IPv6 PIM.
 - Select the RP Set tab.
RP Set Field Descriptions
Use the descriptions in the following table to use the RP Set tab.
 Name  |
 Description  |
 GroupAddress  |
 Specifies the IPv6 address of the multicast group. When combined with the group mask, this value identifies a group prefix for which the address is a static RP.  |
 GroupMask  |
 Specifies the address mask of the multicast group. When combined with the group address, this value identifies a group prefix for which the address is a static RP.  |
 Address  |
 Specifies the IPv6 address of the static RP.  |
 HoldTime  |
 Specifies the hold time of the static RP. The value is 0.  |
 ExpiryTime  |
 Specifies the minimum time remaining before the static RP is down. The value is 0.  |
