Use statistics to help you monitor Open Shortest Path First (OSPF) performance. You can also use statistics in troubleshooting procedures. OSPF range statistics include area ID, range network address, range subnet mask, range flag, and LSDB type.
Switch:1#show ip ospf stats
                         OSPF Statistics - GlobalRouter
       NumBufAlloc: 1138
        NumBufFree: 1138
   NumBufAllocFail: 0
    NumBufFreeFail: 0
          NumTxPkt: 1144
          NumRxPkt: 2287
      NumTxDropPkt: 0
      NumRxDropPkt: 0
       NumRxBadPkt: 0
         NumSpfRun: 19
        LastSpfRun: 0 day(s), 00:26:15
       LsdbTblSize: 7
     NumAllocBdDDP: 5
      NumFreeBdDDP: 5
       NumBadLsReq: 0
    NumSeqMismatch: 0
     NumOspfRoutes: 7
      NumOspfAreas: 0
NumOspfAdjacencies: 3
       NumOspfNbrs: 3
NumEnabledOspfAreas:0
Use the data in the following table to use the show ip ospf stats command.
 Variable  |
 Value  |
 vrf WORD<1-16>  |
 Specifies a VRF instance by VRF name.  |
 vrfids WORD<0-16>  |
 Specifies a VRF or range of VRFs by ID.  |
