Use the following procedure to generate the private and public key pair for the specific cryptography type.
 - Select Certificate.
 - Select the Key-Pair tab.
 - Select Insert.
 - In the Type field, select the cryptography type.
 - In the Size field, type the size of the key.
 - Select Insert.
Key-Pair Field Description
Use the data in the following table to use the Key-Pair tab.
 Name  |
 Description  |
 Type  |
 Specifies the cryptography algorithm used to generate the key-pair. Only RSA is supported.  |
 Size  |
 Specifies the size of the key-pair to be generated. Only 2048 is supported.  |
 Name  |
 Specifies the name of the key-pair generated for the subject. This name is auto-generated as the combination of key-type and key-size.  |
