Configure a PIM virtual neighbor if the next hop for a static route cannot run PIM, such as the Virtual Router Redundancy Protocol (VRRP) address on an adjacent device.
 - Select PIM.
 - Select the Virtual Neighbors tab.
 - Select Insert.
 - Specify the IP address of the virtual neighbor.
 - Specify the interface index for the PIM interface.
 - Select Insert.
Virtual Neighbors Field Descriptions
Use the descriptions in the following table to use the Virtual Neighbors tab.
                                 Name  |
                                 Description  |
                                 Address  |
                                 Specifies the IP address of the neighbor.  |
                                 IfIndex  |
                                 Specifies the IP address of the PIM interface.  |
