Enable IPv6 ECMP
Use the following procedure to enable IPv6 ECMP globally or on a specific VRF. IPv6 ECMP is disabled by default.
Use the data in the following table to use the ipv6 ecmp command.
 Variable  |
 Value  |
 enable  |
 Enables IPv6 ECMP globally. Note:
