Use the following procedure to view the Intermediate-System-to-Intermediate-System (IS-IS) system statistics.
 - Select Stats.
 - Select the System Stats tab.
System Stats Field Descriptions
Use the data in the following table to use the System Stats tab.
 Name  |
 Description  |
 CorrLSPs  |
 Indicates the number of corrupted in-memory link-state packets (LSPs) detected. LSPs received from the wire with a bad checksum are silently dropped and not counted.  |
 AuthFails  |
 Indicates the number of authentication key failures recognized by this Intermediate System.  |
 LSPDbaseOloads  |
 Indicates the number of times the LSP database has become overloaded.  |
 ManAddrDropFromAreas  |
 Indicates the number of times a manual address has been dropped from the area.  |
 AttmptToExMaxSeqNums  |
 Indicates the number of times the IS has attempted to exceed the maximum sequence number.  |
 SeqNumSkips  |
 Indicates the number of times a sequence number skip has occurred.  |
 OwnLSPPurges  |
 Indicates the number of times a zero-aged copy of the system's own LSP is received from some other node.  |
 IDFieldLenMismatches  |
 Indicates the number of times a PDU is received with a different value for ID field length to that of the receiving system.  |
 PartChanges  |
 Indicates partition changes.  |
 AbsoluteValue  |
 Displays the counter value.  |
 Cumulative  |
 Displays the total value since you opened the Stats tab.  |
 Average/sec  |
 Displays the average value for each second.  |
 Minimum/sec  |
 Displays the minimum value for each second.  |
 Maximum/sec  |
 Displays the maximum value for each second.  |
 LastVal/sec  |
 Displays the last value for each second.  |
