Configure a Vendor Class
Perform this procedure to configure a vendor class. If the string matches the vendor class identifier (VCI) provided by the DHCP client, then the DHCP client is part of that vendor class.
The switch follows inheritance and precedence rules for configured DHCP Server options. For more information, see DHCP Server.
Configure a vendor class:
Switch:1>enable Switch:1#config t Switch:1(config)#ip dhcp-server vendor-class 20 matches printer <cr>
The following table defines parameters for the ip dhcp-server vendor-class command.
| Variable | Definition |
| WORD<1-255> |
                                 Specifies the vendor class ID.  |
                                 domain-name WORD<1-128>  |
                                 Specifies the domain name advertised on the vendor class.  |
                                 matches WORD<1-128>  |
                                 Specifies the vendor class identifier for the vendor class.  |
                                 server-name WORD<0-64>  |
                                 Specifies the server name of the TFTP server advertised on the vendor class.  |
                                 tftp boot-file-name WORD<0-128>  |
                                 Specifies the boot file name.  |
                                 tftp server-ip {A.B.C.D}  |
                                 Specifies the IPv4 address of the TFTP server advertised on the vendor class.  |
                                 vendor-option-data <1-255>  |
                                 Specifies the file name of the TFTP boot image advertised on the vendor class.  |
                                 value WORD<0-128>  |
                                 Specifies the data value for the vendor class.  |
