Display individual DHCP-relay statistics for specific ports to manage network performance.
Slot and port information can differ depending on hardware platform.
View DHCP-relay statistics:
Switch:1>enable
Switch:1#show interfaces gigabitethernet statistics dhcp-relay
                                Port Stats Dhcp
PORT_NUM VRF NAME         NUMREQUEST NUMREPLY
1/12     GlobalRouter     0          2
1/13     GlobalRouter     3          2
2/3      GlobalRouter     0          2
Use the data in the following table to use the show interfaces GigabitEthernet statistics dhcp-relay command.
 Variable  |
 Value  |
 vrf WORD<1-16>  |
 Specifies a VRF instance by VRF name.  |
 vrfids WORD<0-255>  |
 Specifies the ID of the VRF.  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (1/1). Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
