Configure multicast access control for a selected IGMP interface or VLAN to restrict access to certain multicast streams and to protect multicast streams from spoofing (injecting data to the existing streams).
You can configure IGMP on a VRF instance the same way you configure the Global Router except that you must first launch the appropriate VRF context.
 - Select IGMP.
 - Select the Access Control tab.
 - Select Insert.
 - Type the number of the slot and port or the VLAN ID that you want to add as a member or select Port or Vlan and then select a port or VLAN from the graphic display.
 - Select ... near PrefixListId.
 - Select a prefix list ID.
 - Select OK.
 - Type the host address and host mask.
 - Select the action mode that you want for the specified host.
 - Select Insert.
Access Control Field Descriptions
Use the data in the following table to use the Access Control tab.
 Name  |
 Description  |
 IfIndex  |
 Specifies the interface where the IGMP entry is enabled.  |
 PrefixListId  |
 Specifies a numeric string that identifies the prefix list.  |
 HostAddr  |
 Specifies the IP address of the host.  |
 HostMask  |
 Specifies the subnet mask that determines the host or hosts covered by this configuration. You can use the host subnet mask to restrict access to a portion of the network for the host.  |
                                 PrefixListName  |
                                 Specifies the name of the prefix list.  |
 ActionMode  |
 Specifies the action for the host identified by HostAddr. The options include the following:
