Configure Endpoint Tracking globally on the switch.
- In ExtremeCloud IQ Site Engine, configure your third-party virtualization platform, and the RADIUS server used for Endpoint Tracking authentication. For information about configuring ExtremeCloud IQ Site Engine, see the ExtremeCloud IQ Site Engine documentation at https://www.extremenetworks.com/support/documentation/.
On the switch, add and configure the RADIUS server as configured in ExtremeCloud IQ Site Engine.
Create and enable Endpoint Tracking on interfaces.
Optionally, if the RADIUS outbound attributes do not include an I-SID value, configure an I-SID offset value, and globally enable I-SID offset for Endpoint Tracking. The I-SID offset value is used to calculate an I-SID value for a switched UNI if no I-SID value is provided by the RADIUS server. In that case, the I-SID value is calculated as follows: I-SID = VLAN ID + configured I-SID offset value.
After optionally configuring an I-SID offset value, enable Endpoint Tracking globally on the switch.
![Note](images/note.png)
If you have previously enabled Endpoint Tracking globally and want to change the currently configured I-SID offset value, you must disable Endpoint Tracking globally, change the I-SID value, and then re-enable Endpoint Tracking globally.
The following table defines parameters for the endpoint-tracking auto-isid-offset command.
Variable |
Value |
<0-15995903> |
The I-SID offset value. The default is 15990000. |
enable |
Enables or disables I-SID offset value globally on the switch. The default is disabled. |
