Configure PoE usage threshold and device type settings, and enable Fast PoE and Perpetual PoE globally on a switch.
Important
After you enable Fast PoE or Perpetual PoE or both, you must save the running configuration file.
If Fast PoE or Perpetual PoE are enabled and you change any other global or port-specific PoE settings, you must resave the running configuration file.
 - Select Chassis.
 - Select the PoE tab.
 - For Usage Threshold%, type the value in percentage for comparing the measured power.
 - For PoweredDeviceDetectType, select the PoE detection type depending on the capabilities of the switch.
 - Select FastPoeEnable.
 - Select PerpetualPoeEnable.
 - Select Apply.
PoE Field Descriptions
Use the data in the following table to use the PoE tab.
                                 Name  |
                                 Description  |
                                 Power(watts)  |
                                 Specifies the nominal power of the Power Sourcing Entity expressed in Watts.  |
                                 OperStatus  |
                                 Specifies the operational status of the main Power Sourcing Entity.  |
                                 ConsumptionPower(watts)  |
                                 Specifies the measured usage power expressed in Watts.  |
                                 UsageThreshold%  |
                                 Configures the usage threshold in percent for comparing the measured power and initiating an alarm if the threshold is exceeded.  |
                                 PoweredDeviceDetectType  |
                                 Configures the mechanism used to detect powered ethernet devices
                                    attached to a powered ethernet port. The options are:
 Note:
The default detection type is automatically configured for the highest PoE standard supported on the switch.  |
                                 PowerPresent  |
                                 Specifies the current power source present on the switch. Available power sources are AC and DC. A value of acOnly indicates that the only power supply is AC. A value of dcOnly indicates that the only power supply is DC. A value of acDc indicates that the two power supplies, AC and DC are supplying power.  |
                                 FastPoeEnable  |
                                 Enables Fast PoE on the switch. The default is disabled.  |
                                 PerpetualPoeEnable  |
                                 Enables Perpetual PoE on the switch. The default is disabled.  |
