Use the port shortcut menu
Perform this procedure to display the port shortcut menu.
- In the Device Physical View, select a port.
 - Right-click the selected port.
Port Shortcut Menu Field Descriptions
Use the data in the following table to use the port shortcut menu.
                         Name  |
                         Description  |
                         Edit General  |
                         Configures the general options for the port.  |
                         Edit IP  |
                         Configures the IP options for the port.  |
                         Edit IPv6  |
                         Configures the IPv6 options for the port.  |
                         Channelization Enable  |
                         Enables channelization for the port.  |
                         Channelization Disable  |
                         Disables channelization for the port.  |
                         Graph  |
                         Displays the statistics for the port.  |
                         Enable  |
                         Enables the port.  |
                         Disable  |
                         Disables the port.  |
