This configuration allows you to build a snooping binding table (SBT) which contains entries from only trusted devices or hosts. This SBT table is used to validate Neighbor Discovery (ND) packets. You can view, create, or delete the entries in the SBT.
Use this procedure to create an SBT entry.
 - Select FHS.
 - Select the Snoop Binding tab.
 - Select Insert.
 - Configure the parameters for the snoop binding.
 - Select Insert.
 - Optional: Select Refresh to update the results.
Snoop Binding Field Descriptions
Use the data in the following table to use the Snoop Binding tab. The system displays a subset of these fields if you select Insert.
 Name  |
 Description  |
 VlanId  |
 Specify the VLAN to which the snooped entry belongs.  |
 Ipv6Address  |
 Enter the IPv6 address assigned to the IPv6 host.  |
 MacAddress  |
 Enter the MAC address of the snooped entry.  |
 InterfaceIndex  |
 Specify the interface on which the entry is learnt.  |
 EntryType  |
 Indicates the type of entry - static (1) or dynamic (2).  |
 EntrySource  |
 Indicates the method entry was learnt from - static (1) or dhcp (2).  |
 ValidTime  |
 Indicates the valid time for the snooped entry.  |
 TimeToExpiry  |
 Indicates the time to expiry of the snooped entry.  |
Use this procedure to display a configured SBT table.
 - Select FHS.
 Name  |
 Description  |
 VlanId  |
 Ipv6Address  |
 MacAddress  |
 InterfaceIndex  |
 EntryType  |
 EntrySource  |
 ValidTime  |
 TimeToExpiry  |
Use this procedure to delete an entry from the SBT table.
 - Select FHS.
 - Select a row from the list to delete.
 - Select Delete.
