Perform this procedure to define vendor options definitions.
The switch follows inheritance and precedence rules for configured DHCP Server options. For more information, see DHCP Server.
Define the vendor options definitions for DHCP server:
Switch:1>enable Switch:1#config t Switch:1(config)#ip dhcp-server vendor-option-def 1 type string Switch:1(config)#ip dhcp-server vendor-option-def 2 type uint32 name firmware <cr>
The following table defines parameters for the ip dhcp-server vendor-option-def command.
| Variable | Definition |
                                 <1-255>  |
                                 Specifies the vendor option definition.  |
                                 type ipv4-address | uinit32 | string  |
                                 Specifies the vendor option definition data type as follows:
                                 name WORD<0-128>  |
                                 Specifies a text label that identifies the vendor option definition.  |
