Perform a General VLAN Action
Perform a general VLAN action to initiate a specific function on a VLAN, such as clearing learned MAC addresses or ARP entries from the forwarding database by performing this procedure.
Perform a general VLAN action:
Switch(config)# vlan action 1 none
Switch(config)# vlan action 1 flushMacFdb
Switch(config)# vlan action 1 flushIp
Switch(config)# vlan action 1 flushDynMemb
Use the data in the following table to use the vlan action command.
                             Variable  |
                             Value  |
                             none  |
                             Configures action to none. This action performs no updates.  |
                             flushMacFdb  |
                             Configures action to flushMacFdb. This action removes the learned MAC addresses from the forwarding database for the selected VLAN.  |
                             flushArp  |
                             Configures action to flushArp. This action removes the ARP entries from the address table for the selected VLAN.  |
                             flushIp  |
                             Configures action to flushIp. This action removes the learned IP addresses from the forwarding table for the selected VLAN.  |
                             flushDynMemb  |
                             Configures action to flushDynMemb. This action removes port members not configured as static from the list of active port members of a policy-based VLAN, and removes MAC addresses learned on those ports for this VLAN.  |
                             flushDynMemb  |
                             triggerRipUpdate  |
                             Configures action to triggerRipUpdate.  |
                             all  |
                             Configures action to all and performs all preceding actions.  |
