Perform this procedure to view the UNI ports associated with particular remote IP multicast routes.
 - Select SPBM Remote.
 - Select the IpMcastRoutes tab.
 - Select an entry.
 - Select the UNI Ports button.
IpMcastRoutes-Uni Ports Field Descriptions
Use data in the following table to use the IpMcastRoutes-Uni Ports tab.
 Name  |
 Description  |
                                 VsnIsid  |
                                 Specifies the VSN I-SID. Layer 2 VSN and Layer 3 VSN each require a VSN I-SID.  |
 Group  |
 Specifies the group IP address for the IP Multicast over Fabric Connect route.  |
 Source  |
 Specifies the IP address where the IP Multicast over Fabric Connect route originates.  |
 NickName  |
 Specifies the nickname.  |
                 EgressVlan  |
 Specifies the egress VLAN of the IP multicast route.  |
 EgressActivePorts  |
 Specifies the egress active ports.  |
