Use the following procedure to configure the aging time globally for the forwarding database.
Use the data in the following table to use the mac-address-table command.
                             Variable  |
                             Value  |
                             aging-time  |
                             Specifies the timeout period for dynamically learned mac addresses on the vlan. The default valus is 300.  |
                             <10–1000000>  |
                             Specifies the range for the aging time.  |
