Perform this procedure to enable Energy Saver globally.
 - Select Energy Saver.
 - Select the Energy Saver Globals tab.
 - Configure the fields as required.
 - Select Apply.
Energy Saver Globals Field Descriptions
Use the data in the following table to use the Energy Saver Globals tab.
 Name  |
 Description  |
 EnergySaverEnabled  |
 Enables Energy Saver globally on the switch. The default is disabled.  |
 PoePowerSavingEnabled  |
 Enables Energy Saver PoE power saving. The default is disabled.  |
 EfficiencyModeEnabled  |
 Enables Energy Saver efficiency mode. The default is disabled. Efficiency mode enables Energy Saver globally and on all ports, it also enables PoE power saving. It also creates a weekday schedule that starts at 6:00 p.m. and ends at 7:30 a.m., and during the weekend Energy Saver is always activated.  |
 EnergySaverActive  |
 Activates Energy Saver on the switch. Energy Saver is deactivated by default.  |
