Use the following procedure to display the SPB-PIM Gateway interfaces neighbor information.
Switch:1>show ip spb-pim-gw neighbor
                          Spb-pim-gw Neighbor - GlobalRouter
INTERFACE ADDRESS         UPTIME                EXPIRE
Vlan26    26.1.1.10       0 day(s), 00:11:36    0 day(s), 00:01:28
Total SPB-PIM-GW Neighbors Displayed = 1/1
Variable definitions
The following table defines parameters for the show ip spb-pim-gw neighbor command.
 Variable  |
 Value  |
 vrf WORD<1-16>  |
 Displays the SPB-PIM Gateway interface neighbor information for a specific VRF name.  |
 vrfids WORD<0-512>  |
 Displays the SPB-PIM Gateway interface neighbor information for a range of VRF IDs.
Note:
Enter a single VRF ID or multiple VRF IDs separated by ‘,‘ or enter a range of VRF IDs ‘x-y‘.  |
