Use the following procedure to view or clear statistics of the number of packets mirrored into I-SID on the mirroring BEB.
 - Select General.
 - Select the Isid-Mirroring Stats tab.
Isid-Mirroring Stats Field Descriptions
Use the data in the following table to use the Isid-Mirroring Stats tab.
                         Name  |
                         Description  |
                         Index  |
                         Specifies the entry that contains Fabric RSPAN statistics information.  |
                         MonitorIsid  |
                         Specifies the actual monitor I-SID value to which the packets are mirrored.  |
                         MirroredPackets  |
                         Specifies the number of packets mirrored into I-SID on the mirroring BEB.  |
                         ClearStats  |
                         Clears the Fabric RSPAN statistics.  |
