Use this task to configure static routes for Management Instances.
For the Management Instance CLIP, you do not need to configure a default or static route. This interface type uses all routing information learned by protocols attached to the VRF. For more information about how to associate a VRF with the CLIP interface, see Create a Segmented Management Instance.
For the Management Instance OOB and VLAN, you must configure a default or static route to reach the next-hop gateway; no routing protocol information is used to access off-link networks.
You can configure up to 100 IPv4 and IPv6 static routes.
Add a static route to configure routing for a Management Instance:
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#mgmt vlan Switch:1(mgmt:vlan)#ip route 192.0.2.2/24 next-hop 198.51.100.1
Variable definitions
The following table defines parameters for the ip route and ipv6 route commands.
 Variable  |
 Value  |
 <A.B.C.D A.B.C.D | A.B.C.D/X>  |
 Specifies the IP address and mask in one of the following formats:
 next-hop <A.B.C.D> or next-hop WORD<0-255>  |
 Specifies the next hop address for the static route. Use an IP in the same subnet as the management VLAN IP address.  |
 weight <1–65535>  |
 Specifies the static route cost. The default is 100 for CLIP, 200 for VLAN, and 300 for OOB. The management CLIP uses an internal static route with a weight of 100. If you use both CLIP and VLAN and need to force all default traffic out the management VLAN interface, configure a default static route with a weight lower than 100.  |
 WORD<0-255>  |
 Specifies the IPv6 address.  |
