Configure the 256–bit MACsec cipher suite on the port 1/3 and verify the configuration.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitEthernet 1/3 Switch:1(config-if)#macsec cipher-suite gcm-aes-256
Switch:1#show macsec status 1/3
                                   MACSEC Port Status
      MACSEC Encryption Replay  Replay   Encryption Cipher CA  MKA-Profile MKA
PortId Status Status    Protect Protect                                    Connect
                                W'dow    Offset     Suite  Name  Name      Status
1/3   enabled disabled enabled  50 ipv4Offset(30) AES-256 mkanka extreme   pending
                  The system displays the following error message if you attempt to configure a cipher suite on a port that is not MACsec capable.
Switch:1>enable Switch:1(config)#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitEthernet 1/2 Switch:1(config-if)#macsec cipher suite gcm-aes-256 Error: port 1/2, Port is not MACSec capable. No MACSec configurations allowed on port
The system displays the following error message if your hardware does not support the MACsec 256-bit cipher suite.
VSP-4900-48P:1>enable VSP-4900-48P:1(config)#configure terminal Enter configuration commands, one per line. End with CNTL/Z. VSP-4900-48P:1(config)#interface gigabitEthernet 1/12 VSP-4900-48P:1(config-if)#macsec cipher-suite gcm-aes-256 Error: port 1/12, MACSec cipher-suite cannot be modified on port. Cipher-suite is by default AES-128
The following table defines parameters for the macsec cipher-suite command.
 Variable  |
 Definition  |
 {gcm-aes-128 | gcm-aes-256}  |
 Configures the cipher suite for encrypting traffic with MACsec. The supported cipher suites are:
 The default is the AES-GCM-128 cipher suite.  |
