Configure a redistribute entry to announce routes of a certain source protocol type into the OSPF domain, for example, static, RIP, or direct. Optionally, use a route policy to control the redistribution of routes.
Enable OSPF globally.
Ensure that a route policy exists.
Change the VRF instance as required to configure OSPF on a specific VRF instance. The VRF must have an RP trigger of OSPF. Not all parameters are configurable on non-default VRFs.
Important
Changing the OSPF redistribute context is a process-oriented operation that can affect system performance and network reachability while you perform this procedure. As a best practice, if you want to change default preferences for an OSPF redistribute context, do so before you enable the protocols.
 - Select OSPF.
 - Select the Redistribute tab.
 - Select Insert.
 - Select an option for the route source.
 - Select enable.
 - Select a route policy.
 - Configure the metric type.
 - Configure the subnet.
 - Select Insert.
Redistribute Field Descriptions
Use the data in the following table to use the Redistribute tab.
 Name  |
 Description  |
 DstVrfId  |
 Specifies the destination virtual router forwarding instance. You cannot configure this variable.  |
 Protocol  |
 Specifies the dynamic routing protocol that receives the external routing information.  |
 SrcVrfId  |
 Specifies the source VRF instance. You cannot configure this variable.  |
 RouteSource  |
 Specifies the route source protocol for the redistribution entry.  |
 Enable  |
 Enables (or disables) an OSPF redistribute entry for a specified source type.  |
 RoutePolicy  |
 Configures the route policy (by name) to use for detailed redistribution of external routes from a specified source into an OSPF domain. Select the ellipsis (...) and choose from the list in the dialog box.  |
 Metric  |
 Configures the OSPF route redistribution metric for basic redistribution. A value of 0 indicates to use the original cost of the route.  |
 MetricType  |
 Configures the OSPF route redistribution metric type. The default is type 2. The cost of a type 2 route is the external cost, regardless of the interior cost. A type 1 cost is the sum of both the internal and external costs.  |
 Subnets  |
 Allows or suppresses external subnet route advertisements when routes are redistributed into an OSPF domain.  |
