Enables the switch to support advanced features by reserving ports as loopback ports. When disabled, you can use all ports on the switch, but advanced features do not work.
When you enable this boot flag, you need to save and reboot with the new configuration.
Exception: only supported on VSP 7400 Series.
Product Notice: For VSP 7400 Series, you must ensure your configuration does not include reserved ports before you enable this feature. If the configuration includes reserved ports after you enable this feature and restart the switch, the switch stops loading the configuration.
enable
configure terminal
boot config flags advanced-feature-bandwidth-reservation [low | high]
Important
A change to the advanced-feature-bandwidth-reservation boot flag requires a reboot for the change to take effect.
show boot config flags
This step only applies to VSP 7400 Series.
show interfaces gigabitEthernet
Enable this feature to the low level.
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#boot config flags advanced-feature-bandwidth-reservation low
   Warning: Please note that the configuration for the following ports 1/31-1/32
            will be removed from the configuration file.
 Are you sure you want to continue (y/n) ? y
    Warning: Please save the configuration and reboot the switch
             for this to take effect.
             Flag advanced-feature-bandwidth-reservation is changed to enable (low).
