Display KHI Port Information
Use the following commands to display key health information about the types of control packets and protocols received on a port and sent to the control processor.
- In the Device Physical View, select a port.
 - Select Port.
 - Select the CPP Stats tab.
CPP Stats Field Descriptions
Use the data in the following table to use the CPP Stats tab.
 Name  |
 Description  |
 Port  |
 Identifies the slot and port.  |
 Packet  |
 Shows the packet type.  |
 PacketName  |
 Shows the name of the packet.  |
 RxPackets  |
 Indicates the number of received packets on the port for the packet type.  |
 TxPackets  |
 Indicates the number of transmitted packets on the port for the packet type.  |
