Display detailed statistics for specific ports to manage network performance.
View statistics for various ports:
Switch:1>enable
Switch:1#show interfaces gigabitethernet statistics verbose
Please widen the terminal for optimal viewing of data.
Port Stats Interface Extended
PORT_NUM IN_UNICST OUT_UNICST IN_MULTICST OUT_MULTICST IN_BRDCST OUT_BRDCST IN_LSM OUT_LSM
1/1 0 0 0 0 0 0 0 0
1/2 11421 10 0 255132 154 412502 0 0
1/3 0 0 0 0 0 0 0 0
1/4 0 0 0 0 0 0 0 0
1/5 0 0 0 0 0 0 0 0
1/6 0 0 0 0 0 0 0 0
1/7 0 0 0 0 0 0 0 0
1/8 0 0 0 0 0 0 0 0
1/9 0 0 0 0 0 0 0 0
1/10 0 0 0 0 0 0 0 0
1/11 0 0 0 0 0 0 0 0
1/12 49811 4388 13200 730098 0 0 0 0
--More-- (q = quit)
Use the data in the following table to use the show interfaces GigabitEthernet statistics verbose command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
