Use the following commands to display KHI information about the performance of the switch.
Switch:1>show khi performance buffer-pool 1
	Slot:1
      CPP:
         UsedFBuffs: 12
         FreeFBuffs: 3060
         RxQ0FBuffs: 0
         RxQ1FBuffs: 0
         RxQ2FBuffs: 0
         RxQ3FBuffs: 0
         RxQ4FBuffs: 0
         RxQ5FBuffs: 0
         RxQ6FBuffs: 0
         RxQ7FBuffs: 0
         TxQueueFBuffs: 0
         NoFbuff: 0
      Network stack system:
         UsedMbuf: 244
         FreeMbuf: 47606
         SocketMbuf: 19
      Network stack data:
         UsedMbuf: 4
         FreeMbuf: 10748
      Letter API message queue:
         QHigh: 0
         QNormal: 0
         FreeQEntries: 51200
Switch:1>show khi performance cpu 1
    Slot:1
         Current utilization: 6
         5-minute average utilization: 5
         5-minute high water mark: 15 (07/20/23 08:15:22)
Switch:1>show khi performance memory 1
    Slot:1
         Used: 6259174 (KB)
         Free: 1933970 (KB)
         Current utilization: 76 %
         5-minute average utilization: 76 %
         5-minute high water mark: 80 (%)
         10-minute average utilization: 76 %
         10-minute high water mark: 80 (%)
         1-Hour average utilization: 76 %
         1-Hour high water mark: 79 (%)
         1-Day average utilization: 76 %
         1-Month average utilization: 0 %
         1-Year average utilization: 0 %
SMLT socket buffer memory usage 0 KB on 0 blocks
The following example shows partial output for the show khi performance memory history command and depending on the hardware platform, you can also display virtual memory history.
Switch:1>show khi performance memory history
    Slot:1
Values indicate VMSize in KB
Pid    Pname                 5-Min    10-Min   1-Hour   1-Day    1-Month  1-Year
 1733  logger                2        2        2        2        --       --
 1751  namServer             24       24       24       24       --       --
 1752  sockserv              5        5        5        5        --       --
 1754  oom95                 106      106      106      106      --       --
 1755  oom90                 106      106      106      106      --       --
 1756  imgsync.x             25       25       25       25       --       --
 1831  logServer             29       29       29       29       --       --
 1832  trcServer             23       23       23       23       --       --
 1834  oobServer             23       23       23       23       --       --
 1836  nickServer            24       24       24       24       --       --
 1837  nickClient            24       24       24       24       --       --
 2451  dhclient-fan          --       --       --       --       --       --
 1840  hwsServer             29       29       29       29       --       --
 1843  redis-server          20       20       20       19       --       --
 2551  restweb_voss.pyz      33       33       33       32       --       --
 2559  hiveagent             10       10       10       9        --       --
 1844  cbcp-main.x           626      626      623      618      --       --
--More-- (q = quit)
         The following example shows partial output for the show khi performance process command.
Switch:1>show khi performance process 1 Slot:1 ----------------------------------------------------------------------------------------------------------- PID PPID PName VmSize VmLck VmRss VmData VmStk VmExe VmLib ----------------------------------------------------------------------------------------------------------- 1 0 init 2152 0 1488 168 132 32 1692 2 0 kthreadd 0 0 0 0 0 0 0 3 2 ksoftirqd/0 0 0 0 0 0 0 0 9819 2 kworker/u4:0 0 0 0 0 0 0 0 5 2 kworker/0:0H 0 0 0 0 0 0 0 7 2 rcu_sched 0 0 0 0 0 0 0 8 2 rcu_bh 0 0 0 0 0 0 0 9 2 migration/0 0 0 0 0 0 0 0 10 2 lru-add-drain 0 0 0 0 0 0 0 11 2 cpuhp/0 0 0 0 0 0 0 0 12 2 cpuhp/1 0 0 0 0 0 0 0 13 2 migration/1 0 0 0 0 0 0 0 14 2 ksoftirqd/1 0 0 0 0 0 0 0 15 2 kworker/1:0 0 0 0 0 0 0 0 16 2 kworker/1:0H 0 0 0 0 0 0 0 17 2 kdevtmpfs 0 0 0 0 0 0 0 --More-- (q = quit)
The following example shows partial output for the show khi performance pthread command.
Switch:1>show khi performance pthread 1 Slot:1 ----------------------------------------------------------------------------------------------------------- TID PID PName CPU(%) 5MinAvg CPU(%) 5MinHiWater CPU(%(time stamp)) ----------------------------------------------------------------------------------------------------------- 1 1 init 0.0 0.0 2 2 kthreadd 0.0 0.0 3 3 ksoftirqd/0 0.1 0.0 9967 9967 kworker/u4:0 0.0 0.0 5 5 kworker/0:0H 0.0 0.0 10005 2551 restweb_voss.py 0.1 0.2 7 7 rcu_sched 0.0 0.0 8 8 rcu_bh 0.0 0.0 9 9 migration/0 0.0 0.0 10 10 lru-add-drain 0.0 0.0 11 11 cpuhp/0 0.0 0.0 12 12 cpuhp/1 0.0 0.0 13 13 migration/1 0.0 0.0 14 14 ksoftirqd/1 0.0 0.0 15 15 kworker/1:0 0.0 0.0 --More-- (q = quit)
The following example shows output for the show khi performance rx-queue command.
Switch:1>show khi performance rx-queue ----------------------- CPP COUNTERS ----------------------- FBUF COUNTERS InUseFBuffs: 0 FreeFBuffs: 3072 Stolen Rx Packets: 0 TxQueueFBuffs: 0 NoFBuffs: 0 PACKET COUNTERS: totalCppEnetRxPkts: 0 totalRxPkts: 0 OamPktsRcvd: 0 IoPktsRcvd: 0 IoCopPktsRcvd: 0 PcapPktsRcvd: 0 Ipv6PktsRcvd: 2796 RxTestPkts: 0 RxCpHbPkts: 0 RxOopPkts: 0 RxMacMgmtPkts: 0 RxIpfixPkts: 0 RxOtherPkts: 0 RxCreditsAdded: 0 MyFramesReceived: 0 totalQueuedPkts: 920329 QueuedOamPkts: 0 QueuedIoPkts: 0 QueuedIoCopPkts: 0 QueuedTestPkts: 0 QueuedOtherPkts: 0 totalDequeuedPkts: 920329 DequeuedOamPkts: 0 DequeuedIoPkts: 920329 DequeuedIoCopPkts: 0 DequeuedTestPkts: 0 DequeuedOtherPkts: 0 totalPktsProcessed: 920329 OamPktsProcessed: 0 IoPktsProcessed: 920329 IoCopPktsProcessed: 0 OtherPktsProcessed: 0 minPktsRcvdAtOneTime: 0 maxPktsRcvdAtOneTime: 0 numCppInterrupts: 0 numTimesWeReceivedPkts: 0 numTimesTmainProcessedPkts: 816006 TxPktAttempts: 0 TxQueuedPkts: 0 TxDequeuedPkts: 0 TxPktsOk: 0 TxTestPkts: 0 TxIpv6Pkts: 0 TxIpfixPkts: 0 TxLsmPktsOk: 0 TxPktsRecovered: 0 totalLldpPktsRcvd 81683 totalDroppedUpnpFilterPKts 0 avgNumPktsRcvdAtOneTime: 0 avgNumPktsProcessedAtOneTime: 0 PACKET ERROR/DISCARD COUNTERS (non-zero counters only) DroppedGlbSpbmDisPkts: 3713 DroppedAllRxPkts: 3713 NODE COUNTERS pRxNodeList count: 0 pRxFreeList count: 0 pRxDirtyList count: 0 OutOfRxNodes count: 0 errorFindingRxBufCount: 0 pTxNodeList count: 0 pTxFreeList count: 0 pTxDirtyList count: 0 OutOfTxNodes count: 0 errorFindingTxBufCount: 0 CPP BUDGET COUNTERS cppHardBudgetCount: 2 cppSoftBudgetCount: 2043 cppTicAbsenceTimeCount: 1 cppMimCount: 0 lastIntPid: 29 numSyncRxFrameEvents: 816006 CPP QUEUE STATS: CPP Priority Queue Num 0 Total Rx Queue Count: 66848 CPP Priority Queue Num 0 Current Rx Queue Count: 0 CPP Priority Queue Num 0 Max Rx Queue Count: 12 CPP Priority Queue Num 1 Total Rx Queue Count: 2286 CPP Priority Queue Num 1 Current Rx Queue Count: 0 CPP Priority Queue Num 1 Max Rx Queue Count: 1 CPP Priority Queue Num 2 Total Rx Queue Count: 66 CPP Priority Queue Num 2 Current Rx Queue Count: 0 CPP Priority Queue Num 2 Max Rx Queue Count: 2 CPP Priority Queue Num 3 Total Rx Queue Count: 0 CPP Priority Queue Num 3 Current Rx Queue Count: 0 CPP Priority Queue Num 3 Max Rx Queue Count: 0 CPP Priority Queue Num 4 Total Rx Queue Count: 13 CPP Priority Queue Num 4 Current Rx Queue Count: 0 CPP Priority Queue Num 4 Max Rx Queue Count: 1 CPP Priority Queue Num 5 Total Rx Queue Count: 33957 CPP Priority Queue Num 5 Current Rx Queue Count: 0 CPP Priority Queue Num 5 Max Rx Queue Count: 277 CPP Priority Queue Num 6 Total Rx Queue Count: 608854 CPP Priority Queue Num 6 Current Rx Queue Count: 0 CPP Priority Queue Num 6 Max Rx Queue Count: 26 CPP Priority Queue Num 7 Total Rx Queue Count: 208305 CPP Priority Queue Num 7 Current Rx Queue Count: 0 CPP Priority Queue Num 7 Max Rx Queue Count: 11 CPP Tx Queue Count: 0 CPP Tx Max Queue Count: 0 Processed 10320 pkts over 2505497 milliseconds = 4 pkts/second
The following example shows partial output for the show khi performance slabinfo command.
Switch:1>show khi performance slabinfo
 Slot:1
Name                   Active  Num     Objsize Objper  Pageper Active  Num
                       Objs    Objs            slab    slab    Slabs   Slabs
nf_conntrack           306     306     224     18      1       17      17
jffs2_refblock         32      32      248     16      1       2       2
jffs2_i                20      20      408     20      2       1       1
ip6-frags              0       0       136     30      1       0       0
UDPv6                  60      60      800     20      4       3       3
tw_sock_TCPv6          0       0       184     22      1       0       0
request_sock_TCPv6     0       0       232     17      1       0       0
TCPv6                  40      40      1600    20      8       2       2
sgpool-128             12      12      2560    12      8       1       1
sgpool-64              12      12      1280    12      4       1       1
sgpool-16              12      12      320     12      1       1       1
cfq_queue              23      23      176     23      1       1       1
mqueue_inode_cache     30      30      544     15      2       2       2
nfs_direct_cache       0       0       184     22      1       0       0
nfs_commit_data        18      18      448     18      2       1       1
--More-- (q = quit)
