View DHCP statistics to manage network performance.
 - Select DHCP Relay.
 - Select the Interfaces Stats tab.
Interfaces Stats Field Descriptions
Use the data in the following table to use the Interfaces Stats tab.
 Name  |
 Description  |
 IfIndex  |
 Identifies the physical interface.  |
 AgentAddr  |
 Shows the IP address configured as the relay on this interface. This address is either the IP of the physical interface or the IP of the VRRP address.  |
 NumRequests  |
 Shows the number of DHCP and BootP requests on this interface.  |
 NumReplies  |
 Shows the number of DHCP and BootP replies on this interface.  |
