View SLPP Guard Status
View current SLPP Guard settings.
Switch:1#>show slpp-guard
                          SLPP-guard Ethertype:   0x8102
                                 Port Interface
Port       Link       Oper       SLPP-guard State      Timeout   TimerCount    ORIGIN
1/1        Up         Down       Disabled   N/A        60        N/A           RADIUS
1/2        Up         Down       Enabled    N/A        120       N/A           RADIUS
1/3        Up         Up         Enabled    Monitoring 60        N/A           RADIUS
1/4        Up         Down       Enabled    N/A        120       N/A           RADIUS
1/5        Down       Down       Disabled   N/A        60        N/A           RADIUS
1/6        Down       Down       Disabled   N/A        60        N/A           RADIUS
1/7        Down       Down       Disabled   N/A        60        N/A           RADIUS
1/8        Down       Down       Disabled   N/A        60        N/A           RADIUS
1/9        Down       Down       Disabled   N/A        60        N/A           RADIUS
1/10       Down       Down       Disabled   N/A        60        N/A           RADIUS
1/11       Down       Down       Disabled   N/A        60        N/A           RADIUS
1/12       Down       Down       Disabled   N/A        60        N/A           RADIUS
The TimerCount column in the preceding example output indicates the time, in seconds, that elapses after SLPP Guard disables a port. When the value TimerCount value equals the Timeout value, the switch re-enables the port.
Variable definitions
Use the data in the following table to use the show slpp-guard command.
 Variable  |
 Value  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
