Perform this procedure to view or modify the Auto-sense configuration on one or more ports. You also have the option to disable Auto-sense on the port but retain the configuration that the system applied dynamically. The dynamic configuration becomes a manual configuration and is visible in the show running-config output.
 - Select AutoSense.
 - Select the Port AutoSense tab.
 - To change the Auto-sense state on a port, select a new value for AutoSense in the appropriate row for the port.
 - Optional: If you disable Auto-sense on a port, select true for AutoSenseKeepAutoConfig to retain the configuration that the system applies dynamically.
 - Optional: Type a value in AutoSenseDataIsid to configure a specific I-SID on the port.
 - Optional: Type a value in AutoSenseWaitInterval to configure a specific interval on the port.
 - Select Apply.
Port AutoSense Field Descriptions
Use the data in the following table to use the Port AutoSense tab.
| Name | Description |
                                 Index  |
                                 Displays the index of the port, written in the slot/port[/sub-port] format.  |
                                 AutoSense  |
                                 Enables or disables Auto-sense on the specific port. The default value is disabled for existing configurations but enabled for new Zero Touch Fabric Configuration deployments.  |
                                 AutoSenseKeepAutoConfig  |
                                 Retains the Auto-sense configuration if you disable Auto-sense on the port. The dynamic configuration becomes a manual configuration and is visible in the show running-config output.  |
                                 AutoSenseState  |
                                 Displays the Auto-sense port state.  |
                                 AutoSenseDataIsid  |
                                 Specifies the Auto-sense data I-SID per port. The port configuration takes precedence over the global data I-SID configuration.  |
                                 AutoSenseWaitInterval  |
                            Specifies the Auto-sense wait time on a port. The port configuration takes precedence over the global wait-interval configuration. The default value is 35. |
