Use this procedure to configure an NTP server address to advertise to clients within a
        DHCP Server subnet.
 - Select DHCP Server.
 - Select the Subnet NTP tab.
 - Select Insert.
 - In Subnet IP, type the subnet network address.
 - In Subnet Mask, type the subnet mask.
 - In IP, type the IPv4 address of the NTP server.
 - Select Insert.
Subnet NTP Field Descriptions
Use the data in the following table to use the Subnet NTP tab.
| Name | Description |
                                 Subnet IP  |
                                 Specifies the network address of the DHCP subnet.  |
                                 Subnet Mask  |
                                 Specifies the subnet mask for the DHCP subnet.  |
                                 IP  |
                            Specifies the IPv4 address for the NTP server that you want to assign to this subnet. You can assign up to eight NTP servers to a subnet. |
