Configure the SSH parameters to generate DSA user key files.
Create the DSA user key file with the user access level set to read-write-all and size of the DSA user key set to 1024 bits:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#ssh dsa-user-key rwa size 1024
The following table defines parameters for the ssh dsa-user-key command.
               Variable  |
               Value  |
               WORD <1–15>  |
               Specifies the user access level. If enhanced secure mode is disabled, the valid user access levels for the switch are:
 If you enable enhanced secure mode, the switch uses role-based authentication. You associate each username with a specific role and the appropriate authorization rights to commands based on that role. If enhanced secure mode is enabled, the valid user access levels for the switch are:
               size <1024–1024>  |
               Specifies the size of the DSA user key. The default is 1024 bits.  |
