Use port-based shaping to rate-limit all outgoing traffic to a specific rate.
The following table defines parameters for the qos if-shaper command.
Variable |
Value |
port {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Specifies the slot and port number to which to apply shaping. This variable is optional. Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
shape-rate WORD<1000-100000000> |
Specifies the shaping rate in Kb/s. If you try to configure a limit that is too high for the port speed, the switch displays the following message: Error: port slot/port, The QOS Egress shaper rate can not exceed the port capability.The default is 0, which means shaping is disabled on the port. |
