Enable MLD Snooping
Use the following procedure to enable MLD snooping on the switch.
 - Select IPv6 MLD.
 - Select Snooping tab.
 - Double-click SnoopEnable for the desired port.
 - Select true to enable MLD snooping.
 - Double-click SsmEnable.
 - Select true to enable SSM.
 - Select Apply.
Snooping Field Description
Use the data in the following table to use the Snooping tab.
                                 Field  |
                                 Description  |
                                 IfIndex  |
                                 Specifies the interface on which you enabled MLD snooping. It specifies the port number if the interface is a brouter port or the VLAN number if the interface is a VLAN.  |
                                 SnoopEnable  |
                                 Indicates the status of MLD snooping on the specified
                                        interface:
                                 SsmEnable  |
                                 Indicates the status of SSM on the specified interface:
