The following table defines parameters for the ip vrf command and the router vrf command.
| Variable | Value |
| WORD<1-16> | Specifies the name of the VRF. |
The following table defines parameters for the interface loopback command.
| Variable | Value |
| <1-256> | Specifies the ID of the loopback interface. |
The following table defines parameters for the ipv6 interface command.
| Variable | Value |
| address WORD<0-255> |
                                 Specifies the IPv6 lookpack interface address. Enter the interface address in the WORD<0-255> portion.  |
| vrf WORD<1-16> | Specifies the name of the VRF. Enter the VRF name in the WORD<1-16> portion. |
The following table defines parameters for the ipv6 ospf command.
| Variable | Value |
| <1-256> |
                                 Specifies the interface ID value.  |
| area {A.B.C.D} |
                                 Specifies the IPv6 OSPFv3 area address, typically formatted as an IP address. Enter the IP address in the {A.B.C.D} portion.  |
