The following sections provide procedural information you can use to configure Fabric Extend (FE) using Enterprise Device Manager (EDM).
Complete the configurations in the following table to configure Fabric Extend.
                             Step  |
                             Procedure  |
                             Description  |
                             1  |
                             Configure the tunnel source address on the Globals tab.  |
                             2  |
                             Configure the IS-IS logical interface for the Fabric Extend tunnel.  |
                             3  |
                             Configure Fabric Extend on the switch at the other end of the tunnel  |
